Coobycs - Rubik's Cube Robot Solver
A Rubik's cube solver using a NodeMCU, Nema17 stepper motors and DRV8825 drivers.
mM
Check the Files section for a video!
I've been fiddling with Rubik's cubes for years and after building a cube solver with Lego I wanted to built something more robust and 'professional'.
A while ago I saw a post on Reddit and I really liked the design but unfortunately no other details were given so I decided to build my own version and publish this to help people looking to build something similar.
It's using a NodeMCU, Nema17 stepper motors and DRV8825 drivers + v-profile and various connectors(some of which are 3d printed) for the frame. I designed a custom PCB to make everything nice and tidy.
Please check tabs:
  • COMPONENTS for materials
  • STEPS for instructions
  • FILES for source files
Coobycs.mp4
A video of a full solve of the robot
MPEG-4 Video - 13.36 MB - 03/04/2023 at 16:50
Download
Zip Archive - 9.48 kB - 03/04/2023 at 16:16
Download
Coobycs PCB.zip
Gerber files for the PCB
Zip Archive - 75.21 kB - 03/04/2023 at 15:41
Download
Coobycs STL.zip
STL files for 3d Printing
Zip Archive - 19.24 kB - 03/04/2023 at 15:31
Download
  • 6 × Nema17 motors with wires
  • 6 × DRV8825 drivers
  • 1 × NodeMCU v2 or similar board
  • 6 × Capacitors 100 uF, 63 V or similar
  • 1 × Power switch
View all 16 components
  • 1
    3D Printed Files
    The v-shape profiles are connected on the outer corners with 90degrees connectors you can buy but for the top/bottom and middle sections, I designed in Tinkercad some connectors you'll have to print. You can find the files also here: https://www.thingiverse.com/thing:5890181
    Print 2x 4 way connectors and 4x 2 way connectors. Print 6x axe connectors that you'll later glue to the center pieces of the cube.
  • 2
    Building the Frame
    Frame
    The frame is based on this reddit post a saw a while ago and I really liked(unfortunately no details were provided so I made my own).
    • Middle: Connect a 7.5cm and a 12.5cm profile with the 2way connector. Repeat 4 times.
    • Top: Connect 4x 10cm profiles with the 4way connector.
    • Bottom: Connect 4x 7.5cm profiles with the 4way connector.
    Use the metal 90degrees connectors to connect the top bottom and middle.
    Motors
    • Insert the motors into the 3d printed connectors and secure them with the screws.
    • Connect motors and the axe with the shafts couplings.
    Rubik's Cube
    Glue the axe's ends to the cube's centers and you'll have to make a few adjustments to get everything fit snuggly.
  • 3
    Electronics
    Here is a schematic that you can use to connect your development board to the motors and drivers.
    As you can see there are quite a few cables and it can get quite messy if you try to use a breadboard.
    To solve this I developed a custom PCB to handle all this. Note that the PCB is designed for a NodeMCU v2 quick drop in.
    The Gerber files you can find attached and you can use a service like https://www.jlcpcb.com or https://www.pcbway.com  to order a custom PCB
    Once you have the PCB, you'll have to solder the capacitors, pins, power connector and switch.  The motor drivers and NodeMCU are dropins.
    Note that each driver has a level which mentions which face/color of the cube it will connect to.  Use these label to orient the cube in the frame and connect the motor cables.
View all 5 instructions
