In the end, we stayed with the idea of making the globe spin from above. We started to work on the physical parts of our project. Using a couple planks, we made a sturdy wooden structure that will hold the motor from above. We've also manually bent a metallic bar in order to make an arch that will hold the LEDs inside the globe.
come.meyer
