First PCB
A project log for Sentinel Reforged
A journey to create an easy-to-use lightsaber that you don't have to fear breaking.
minifig404minifig404 03/31/2023 at 16:570 Comments
Well, here it is. Gen 0 hardware:
Assembled hardware above, raw PCBs below:
It's too long to fit inside the saber, but I'm already working on a new revision that should fix that issue.
Hardware used in this version:
Firmware (and therefore hardware features) have not progressed much since the last update. Instead, I've been trying to focus on hacking together an Android app to control the BLE side. For those with older phones, Bluefruit is an option, but it won't install on my phone, and nRF Connect is only vaguely usable. Once I get the hardware shrunken down enough to fit in a lightsaber hilt, I am going to need a much more usable app for demoing the prototype.
As for the schematic, I'm not committed to the hardware yet. I'm going to have to detour for a bit, juggle details, and then settle on a final circuit. You'll see some of the juggling when I post about the gen1 PCB.
