![Combining all PCBs to a Macro Pad](https://storage.ko-fi.com/cdn/useruploads/display/bc0e1bd9-05d6-4692-b44d-48787fdfe832_-lhopdu.jpg)
My next goal was to get a full macro pad working and since JLCPCB sends you always 5 PCBs as a minimum, there were still a few more rows with 4x1 Atoms left.
The assembly was labor intensive as I had to bake all PCBs first, solder them to the side connector and apply the fixes with some bodge wires:
Next, I extended my QMK firmware and got all diplays working (after some debugging) - Halleluja!
There were still some minor issues, not all displays worked trouble-free, extending the FFC is not easy :(
Even though my intention with the Atom's side-connectors was to make it easily buildable and affordable for everyone, it turned out quite some work. Maybe a ready made PCB would be worth a try...
Also my used MCU, the STM32F407 became unavailable, which made me think about alternatives.
Luckily the state of the RP2040 QMK branch looked already promising so that I decided to convert the macro pad to the RP Pico!
