First attempt, first failure and the first fix.
A project log for Build Your Own Voice Control Module
Add voice control to any projects with an easy-to-build combination of off-the-shelf hardware and open source software.
dennisDennis 04/08/2023 at 16:040 Comments
I loaded the latest and greatest operating system from the Raspberry Pi site and then followed the procedure to install the drivers for the 4 mic array from Seeed Studios. And for whatever reason, the Raspberry Pi could not find the 4 mic array hat. So I reformatted the SD card and loaded the legacy version operating system (2022-09-22-raspios-bullseye-armhf-full.img), followed the 4mic array procedure again, and the Raspberry Pi was able to find the 4 mic array as seen from the screen shot of the terminal below. Yay!
