Servo Library
A project log for Sly Bug
Fluffbug but with smart servos
dehipudeʃhipu 04/18/2023 at 17:440 Comments
I finally made some progress on the library for CircuitPython for controlling the smart servos. For now I only have the basics, and I don't support SYNC WRITE (though I do have WRITE and REG WRITE, so you can move them all at once). But you can already set the id, set target, speed and time, and read load, position and voltage/temperature. That's basically all we are going to need. The code goes something like this:
import struct
class ServoBus:
    def __init__(self, uart):
        self.uart = uart
    def _chcecksum(self, data):
        checksum = 0
        for byte in data:
            checksum = (checksum + byte) & 0xff
        return checksum ^ 0xff
    def send(self, servo_id, command, data=b'', reply=True):
        buf = bytearray(len(data) + 5)
        buf[0:1] = b'\xff\xff'
        buf[2:4] = struct.pack('>BBB', servo_id, len(data) + 2, command)
        buf[5:-1] = data
        buf[-1] = self._chcecksum(memoryview(buf)[2:-1])
        sent = self.uart.write(buf)
        readback = self.uart.read(sent)
        #print(readback)
        if not reply:
            return
        b = self.uart.read(1)
        while b == b'\xff':
        if b is None:
            raise RuntimeError("No reply")
        reply_len = self.uart.read(1)[0]
        reply = bytearray(reply_len + 3)
        reply[0] = b[0]
        reply[1] = reply_len
        reply[2:] = self.uart.read(reply_len)
        if self._chcecksum(memoryview(reply)[:-1]) != reply[-1]:
            raise RuntimeError("Bad checksum")
        return reply
    def ping(self, servo_id=0xfe):
        reply = self.send(servo_id, 0x01)
        return reply[2]
    def read8(self, servo_id, register, length=1):
        reply = self.send(servo_id, 0x02, struct.pack('>BB', register, length))
        return reply[3:-1]
    def read16(self, servo_id, register, length=1):
        reply = self.read8(servo_id, register, length * 2)
        return struct.unpack('>' + 'H' * length, reply)
    def write8(self, servo_id, register, *params, bulk=False):
        write_command = 0x04 if bulk else 0x03
        data = bytearray(len(params) + 1)
        data[0] = register
        data[1:] = bytes(params)
        reply = self.send(servo_id, write_command, data)
        return reply[2]
    def write16(self, servo_id, register, *params, bulk=False):
        data = bytearray(len(params) * 2 + 1)
        data[0] = register
        data[1:] = struct.pack('>' + 'H' * len(params), *params)
        return reply[2]
    def commit(self, servo_id=0xfe):
        reply = self.send(servo_id, 0x05, reply=False)
class SCS0009:
    def __init__(self, servo_bus, servo_id, reverse=False):
        self.servo_id = servo_id
        self.servo_bus = servo_bus
        self.reverse = reverse
    def set_id(self, new_id, permanent=True):
        if permanent:
            self.servo_bus.write8(self.servo_id, 0x30, 0)
        return self.servo_bus.write8(self.servo_id, 0x05, new_id)
    def set_torque(self, value, bulk=False):
        return self.servo_bus.write8(self.servo_id, 0x28, value, bulk=bulk)
    def set_target(self, value, bulk=False):
        if self.reverse:
            value = 1023 - value
        return self.servo_bus.write16(self.servo_id, 0x2a, value, bulk=bulk)
    def set_time(self, value, bulk=False):
        return self.servo_bus.write16(self.servo_id, 0x2c, value, bulk=bulk)
    def set_speed(self, value, bulk=False):
        return self.servo_bus.write16(self.servo_id, 0x2e, value, bulk=bulk)
    def get_position(self):
        value = self.servo_bus.read16(self.servo_id, 0x38, 1)[0]
        if self.reverse:
        return value
    def get_speed(self):
        return self.servo_bus.read16(self.servo_id, 0x3a, 1)[0]
    def get_load(self):
        return self.servo_bus.read16(self.servo_id, 0x3c, 1)[0]
    def get_voltage(self):
        return self.servo_bus.read8(self.servo_id, 0x3e, 1)[0]
    def get_temperature(self):
        return self.servo_bus.read8(self.servo_id, 0x3f, 1)[0]
    def commit(self):
        return self.servo_bus.commit(self.servo_id)
Next up is to get the walking code to use this, and then see what improvements we can do to it using the time/speed settings.
