Micro 2x Dc Motor + 2x Servo.
A project log for Scorpion - Dual Rotor Heli
Micro Drone with pivoting Dual Ducted Rotors.
saulSaul 04/21/2023 at 03:010 Comments
Pcb with motor breakout made it in a couple days early.
Clearance is spot on but might want a heatsink. Thinking about pin options.
Ld293D Motor driver has 2 channels @600ma but takes 4 digis + 2 pwms on the enable pins.
Its the same ic from the original Motor Shield, not much current but high motor voltage.
I think I will print a Test stand arm to try to measure thrust and test Steering...
