4 to 1 multiplexer
A project log for The Cardboard Computer
My goal is a 4-bit cpu using discrete transistors. I am learning from scratch as I have never worked with hardware at the gate level.
Mark Nesselhaus 12/25/2016 at 22:461 Comment
December 25, 2016 - The start of laying out the cardboard logic chips ( might as well call them very large chips or VLC's )
I will be running out of diodes before the end of this and the dmux build but at least I will get started. The logic is very basic and will end up being modified by the time I am finished. Logisim likes the circuit so far.
Yann Guidon / YGDES wrote 12/26/2016 at 06:47 point
You can get a thousand diodes for a few bucks these days... it just requires a bit of patience for the delivery :-)
