February 13, 2017 - Converting ALU input levels
A project log for The Cardboard Computer - IO is my name
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
dr-cockroachDr. Cockroach 02/14/2017 at 01:462 Comments
Spent some time today wiring up a circuit to convert the lower 5 volt logic 1's to 12 volts. I am using just a basic non-inverting buffer using two not gates for each input of the ALU. So far I have one board that takes care of the A inputs. Next I will wire up the same board again for the B inputs. The photos below show the ALU and the newer level converter board. I will be adding some leds as power indicators.
Morning.Star wrote 02/14/2017 at 06:37 point
Hey Mark
Is that a Black Adder? wikipedia.org/wiki/Blackadder_Goes_Forth ? Its even got a Darling...ton array.
Sorry British humour lol :-)
Dr. Cockroach wrote 02/14/2017 at 07:16 point
:-D
