I have updated the instruction card buy reducing the magnets down to two. One for the reader pad and the other for the card. I have also added foil to the reader pad contacts and now have very good reliable contact between card and pad. I am also enclosing the card using the #Origaime (Cardware-bis) method.
Ceramic magnets are now going to be used as the pull is now enough to provide reliable contact.
