3. Speed Control
A project log for 3D Pottery Machine for Kids v2
Cornstarch pottery machine for kids' STEM education
guillermo-perez-guillenGuillermo Perez Guillen 04/08/2023 at 21:100 Comments
As part of the hardware, in the image below I show you the schematic diagram of the speed control.
How does it work?
Below I show you an image of these devices.
In this way I optimized the spaces, and the energy consumption is lower with this Arduino Nano 33 BLE Sense board. Next I show you the code.
speed_control.ino
//AUTHOR: GUILLERMO PEREZ GUILLEN
#define POT A0  // Pot 10k
int raw_pot; // Store value of the pot
int duty;   // duty cycle - PWM
int STBY = 10;        // standby pin
// motor A
int PWMA = 3;        // velocity
int ain1 = 9;
int ain2 = 8;
// motor B
int PWMB = 5;        // velocity
int bin1 = 11;
int bin2 = 12;
void setup(){
  pinMode(STBY, OUTPUT);
  pinMode(PWMA, OUTPUT);
  pinMode(ain1, OUTPUT);
  pinMode(ain2, OUTPUT);
  pinMode(PWMB, OUTPUT);
  pinMode(bin1, OUTPUT);
  pinMode(bin2, OUTPUT);
void loop(){
  raw_pot = analogRead(POT);
  duty = map(raw_pot, 0, 1023, 0, 255); // range vaalue from 0-255
  mover(1, duty, 1);                                // motor 1, velocity, forward
  mover(2, duty, 1);                                // motor 2, velocity, forward
  delay(50);                                        // 50 ms
void mover(int motor, int velocidad, int direccion){    //Let's define the move function,        a acciona un motor, fijar su velocidad y el        sentido de giro. Definimos:    //motor:        llamaremos 1 al motor A, y 2 al motor B
                                                        //velocity: from 0 to 255
                                                        //direction: 0 for clockwise, 1 for counter-clock wise
digitalWrite(STBY, HIGH);          //disable standby to move
 boolean inPin1 = LOW;             // we create the boolean variable (it can only be HIGH/LOW) inpin1
 boolean inPin2 = HIGH;             // and we assign the value LOW. To inPin2 we give the value        HIGH
if(direccion == 1){
inPin1 = HIGH;
inPin2 = LOW;
if(motor == 1){
digitalWrite(ain1, inPin1);
digitalWrite(ain2, inPin2);
 analogWrite(PWMA, velocidad);
  }else{
    digitalWrite(bin1, inPin1);
    digitalWrite(bin2, inPin2);
    analogWrite(PWMB, velocidad);
void stop(){                           // standby action
  digitalWrite(STBY, LOW);
