- To prepare our light flower we need :
- We've Gathered the Necessary Materials : You'll need artificial flowers, thin copper wire, LEDs, batteries or a power supply, electrical tape, scissors and a hot glue gun, make sure the copper wires of the LEDs are long enough to reach the stem of the artificial flower, Attach the LEDs to the flowers: use the insulating tape to attach the copper wires of the LEDs to the stem of the artificial flower, connect the wires.
- Test the connections: Before continuing, check if the connections are working correctly. Connect the batteries or power supply and check if the LEDs light up as expected, Reinforce the connections. To conclude, the led flowers have this opportunies to detect the obsucrity ( open flowers ) and the light (close flowers), so it' beneficial for everyone.
- this part, a straw was put and two gears located at the ends of the circle and two petals to allow the opening and closing of the petals, a translational movement
- These are small gears dyed green in order to arrange them around a circle around which the petals will be
- This is our Arduino board which is programmer which is connected to our flowers in order to allow it a movement of translation and rotation (angles, length ..)
- This is a mini support for our petals the gears will be arranged around and they would be bulging by a golden color
- This is a draft a diagram of the different components of our flowers.
- On this plate of Arduine, we finalized our program so that it adapts and adapts well to the requirements of our project.z
- Then, This is our vase in which we will implore our rod and a wire will pass through below which will be connected to the light sensors
assia
