12/06 : Petals
A project log for Flower Gang
A mechanical flower
romanelemieuxromane.lemieux 06/13/2023 at 11:360 Comments
The gears responsible for opening the petals were designed using a gear simulator, which we modified to suit our project requirements. Some modifications included removing certain teeth and adding a hole in the center. Throughout the process, we encountered challenges with the dimensions and had to make multiple attempts to achieve the desired outcome.
