Check the microphone array
A project log for Portable Sound Visualization AR Device
A portable AR device that superimposes an image showing the location of a sound source on an image captured by a camera.
airpocketAIRPOCKET 05/09/2023 at 04:580 Comments
The microphone array used in this project is the 6+1 microphone array from Sipeed. It has a total of 7 MEMS microphones mounted at the vertices and center of a hexagon, with 3 microphones arranged along each of the 3 axes.
There are 10 pins on the back of the array for data transmission and reception.
In addition, there are 12 NeoPixel LEDs mounted around the perimeter of the PCB, which can be used to display the direction of the sound source using only the PCB.
