This got more attention than i thought
A project log for Lightup breadboard
Each line of the breadboard has an LED that glows based on the voltage on that line
rasmusviil0rasmusviil0 05/18/2023 at 12:200 Comments
... I mean I hoped this would be the response but i didn't think it would actually happen. A short article the project but there really isn't more to say https://hackaday.com/?p=587271 and also talked about on the podcast https://hackaday.com/?p=588642 (16 minutes in for 2 minutes) complete with messing up my name thus giving me a new name. Thank you.
Special thanks to Kuba Sunderland-Ober who gave great suggestions in the comments. In the long run i will be trying to implement the 2 color LED and adjustable reference points but for now i will try to
a) control LED current and
b) turn it into a PCB
so.
Current control
right now the setup for one led looks like this.This simply will not do. An alternative to this was pitched with a separate voltage source for the LEDs from the OpAmps and a transistor but i asked around an got this The OpAmp has enough oomph to supply the current.
The PCB
I'm using KiCad for this. Nothing interesting to show jet but i'll talk about some things i'm thinking about.
my last method was...unreliable. I am considering a spring loaded connector that feels like it could get pricey but i am not clever enough with mechanics to come up with an alternative so i might have to bite the bullet.
last time it was a LiPo battery connector but needed to be driven from a controllable power supply because i added it last minute. This time i'm thinking USB connector.
for the opamps when the signal is close to 0V.
