Dealing with the cores
A project log for Magnetic Core Memory The Dr Cockroach Way
My not so fancy example of Magnetic Core Memory using fairly cheap cores and free parts from my junk box.
dr-cockroachDr. Cockroach 04/27/2023 at 11:562 Comments
April 27, 2023 - The cores that I bought via Ebay came from Bulgaria and I have no idea of the core material specs. Andy Geppert told me what he used as far as a voltage and current with his Core64 project so I started with that but with these cores I was not getting consistent results. With a lot of flip cycles, I am now Writing and Reading at 13.5 Volts at 270 mA in the X and Y matrix wires. The two 47 Ohm resistors actually measure out as 50 Ohms. So far today I have not had a mis-read and feeling that I am on the right track as the cores held there state overnight.
Dr. Cockroach wrote 04/27/2023 at 14:48 point
Heh, a cake roll....  I think buying the cores is easier over all ;-)
Ken KD5ZXG wrote 04/27/2023 at 14:39 point
Rolling VHS tape to a tight straw held together by Scotch tape and slicing donuts with a razor does not work. No detectable flip with reasonable cross-currents. Maybe too much icing, since its not really a donut but a cake roll.
