[E2][P][A] Clamp face flattened, motors installed and holder attempted
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 03/12/2024 at 12:420 Comments
Here's a progress update of what's happened in the past 2 days.
Face flattened and holes tapped
The technician sounded impressed by the aluminium 3D print, but could visibly see that one side of the supposed-to-be-8mm section was shorter than the other side. When in the machine, I believe he said that there was 3/4 of a millimetre in difference between the left and right sides. We assumed that the bottom face of the 8mm thick section was flatter.
The M6, 3x M4 and 4x M2 were all tapped.
I also got some M4x6 grubs and M4x12 and M5x12 bolts for the coaxial heatblock and motor mounts. I chose M5x12 for the latter as they only had 5x M4x6 in stock and much more M5s, and I conveniently designed the motor hardware to accept M5s.
The clamp bolts stopped turning essentially immediately when tightening. I tighten each pair of diagonals. The gasket was also a lot easier to align now.
Did a test fit and it all goes together rather nicely. Not quite sure how much to tighten the heatsinks though.
I also looked at the gasket again and there were light arc indentations, suggesting that the PTFE is still flexible enough to provide sealing.
Motors installed
As it turns out, the cables that came with the motors are actually doubled up. It's an 8-wire ribbon cable that terminates to 2 motors on either end. I was trying to get some convoluted method so that i could identify which cable is what, but then I remembered that I bought some numbered cable markers and just used 2, 4, 6 and 8 on the motor that has the left termination on the Oct Pro (so Extruder 8 would be the last extruder). It does seem that the 1m cables will reach the expected location of the Octopus Pro
Then I tried Tesa fabric tape for the first time and it does look a lot better and more professional than multicoloured ribbon wire.
Also notice that I was able to find a thin-cap M5x25 bolt and I was able to use a regular M5 nut on the X carriage.
Right now I'm just waiting on bolts and wires to come in so that I can put the DDEs on.
Hotend holder and cover printed
It's been a while since I've used the 3D printers my uni happens to have. First time using this bed material and it looks and sticks well so far. I had to tweak and redesign the hotend holder twice due to tolerance issues (and I didn't have M3x8 bolts like I thought I had, but loads of M4x8s).
[13 Mar: 05:00] I've put the hotend mostly together, but understandable misalignments mean that I'm not quite able to align and fit the 8 PTFE couplers:
[13 Mar: 17:00] Lots more printer tuning and for an extra 7 mins of print time, the print came out much better:
New print on the right. The improvements are mostly dimensional accuracy, but the walls also are visibly better.
It still didn't work though, but I was able to get the heatsinks to align when the holder was not installed, allowing filament to slide through a bowden tube without it catching hard on any surfaces. Thus, it does seem like it's still a hotend holder issue.
