It's tricky! It's tricky, tricky, tricky!
A project log for The Grimoire Macropad
A macropad build that is probably more trouble than it is worth.
mrpendentmrpendent 07/06/2023 at 01:160 Comments
The config utility has been updated.
It's name has been changed to "Cantrip". Although I liked "Scribe" (because that would be how you would record items in a grimoire) but Cantrip sounds a lot cooler. And if this project is about anything, it's about style over substance.
So here's a glimpse of it now:
There's a lot here, so let's have a look:
Obviously there is still work that needs to be done, but it's coming along. Right now it can open a file, read it, and dump the contents to the console. Not particularly useful, but...
TODO: Cantrip
Once I get these things done (and the board built) it will be time to work on the shell. Getting closer and closer
