Nearly working
A project log for Listen to the Op Amp´s
Can you hear the difference between Op Amp´s? Yes! With this headphone amplifier.
stephan-martinStephan Martin 09/03/2023 at 09:300 Comments
About 80% finished:
The ZIF socket does not fit into DIP socket holes, it needs larger holes, so i soldered it "on top" like a SMD part... Further it seems i forgot to order some parts, so its back to order more parts...
