- Create schematic for main system
- Design PCB for main system
- Add more error trapping to code
- Rewrite code to use uasyncio instead of _thread for more reliable multitasking
- Add webserver and small DB to allow remote configuration of moisture thresholds for each plant as well as manual control of the pumps and valve
- 3D print a custom case for the electronics
- 3D print custom cases for the exposed parts of the Chirp sensors
- Possibly add a battery pack, charger and small solar panel to make it run completely sustainably
