The upper tower
A project log for Chaotic Lighthouse
A circuit sculpture to participate in the 2023 op amp challenge.
mabe42MaBe42 05/27/2023 at 15:350 Comments
The upper tower is a rather simple structure with a pentagonal cross-section. All made from brass wire, V+ in the center, diodes building a roof-like structure and some 10M resistors and diodes (some are SMD) to provide mechanical stability.
