Logic simulation
A project log for The simplest 4-bit RISC CPU
In this project, I attempt to build a very simple 4 bit RISC CPU. The goal was to design a RISC processor and computer. *Sponsored by PCBway
marsianin245Marsianin245 06/04/2023 at 20:280 Comments
Simulated the 4-bit CPU logic in Logicsim simulator to verify the design. Logical model includes all chips, registers and EEPROM memory.
Simulated execution of short programs by the processor. For example, simulated this program
instruction (byte); upper 4 bits: opcode; lower 4 bits data/address
00  -  no-op:   nothing happens
10   -  clears A register;   A: 0
21   - Add 1 to A;               A: 1
24  - Add 4 to A;              A: 5
25  - Add 5 to A;              A: 10
21   - Add 1 to A;               A: 11
40  - Jump conditional to address 0, if flag carry is on;  false
26  - Add 6 to A:              A: 1 and Flag carry
41   - Jump conditional to address 1, if lag carry is is on; true   Jump executed on address 1
