partially assembled PCB
A project log for The simplest 4-bit RISC CPU
In this project, I built a very simple 4 bit RISC CPU. *Sponsored by PCBway
marsianin245Marsianin245 07/25/2023 at 05:130 Comments
partially assembled and tested: 5v vcc supply, timer, instruction counter.
Timer is generating clock approximately 1 Hz.
Instruction counter increments on falling edge of clock pulses,
counts from 0 to 15.
