Genesis
A project log for Atomic Force Microscope - from ground up
The aim of this project is to make high grade all diy AFM.
100dollarhacker100dollarhacker 06/03/2023 at 20:420 Comments
There are few steps to make AFM.
(Probably there are more steps, we will uncover them as project continues)
XY movement has a very good explanation in Lego2Nano with electric schematic and software algorithms.
For force measure we will use Quartz fork instead of laser one. For two main reasons, first QTF is easy to fabricate at home for a few dollars. Second it eliminate the need for complex laser adjust mechanism and it's electronics.
