Improvements we want:
- find a better solution for the whale tale:
- internal or external skeleton
- more flexible material
- better rope, because nylon is not the best, and the one we tried before was worse
- make better support to hold the gears
dig holes in the egg, for sticks to go through the whole egg and hold the gears in place
- get a better grip on the motors: choose the best type, most efficient connection in the channels, for a better experience with the remote controller
- balance the weight of the engine
- make it more **pretty**, because aesthetics you know
Issues we met:
- the busy printing machines
- the headache to figure out how to slow down the speed of the servo for the whale
- the constant redoing of the gears
- the 2 back wheels going in different directions
- find a structure for the gears
- articulation of the tail
- the imbalance of the weight
- the mixing of the cables inside
