Grayscale display test
A project log for Mechanical Display
This is a mechanical display utilizing an array of pixel units driven by servos.
airpocketAIRPOCKET 06/28/2023 at 02:000 Comments
A "mechanical display" consists of a single display unit composed of a 4x4 dot pixel unit. By connecting multiple display units together, a larger display can be created. After creating the display unit, I made a grayscale display plate for visibility testing.
Based on the actual test results, the evaluation is as follows:
The speed of operation was faster than expected, and it may be possible to achieve around 10 frames per second (FPS). However, I do not want to imagine the noise and power consumption in doing so.
Although it can be used as a grayscale display, the visibility is not good due to the white base plate and servo cables being visible through the gaps in the pixel units. The parts should be changed to black, and the gaps in the pixel units should be minimized as much as possible.
The idea of using a plate with a mountain-shaped pattern, painted in black and white on both sides to represent grayscale depending on the angle, seems to work better than expected. However, since it was created using an FDM 3D printer, it was challenging to achieve the desired color separation through painting. It is necessary to consider alternative methods of coloring.
