Magical Runtime
A project log for 48 Hour Rechargeable Night Light
A Laptop Li Cell, TP4056 charge board, and some LEDs walk into a bar
theonetruestickmantheonetruestickman 07/15/2023 at 18:111 Comment
A couple days into our trip I had free time and finished assembling everything into the case and started runtime test.
Observations:
After 72 hours of continuous run I went back to check my math. It turns out I mis-read/mis-remembered the cell capacity and it's 13.3Wh, not 3.7Wh, which means I should have about nine days of runtime with the current ~17mA configuration. I guess it meets original design requirements.
Future thoughts:
I'm not sure if all of those can be done well at the same time or not but it's percolating.
jocktmpbd7mr wrote 01/08/2024 at 17:26 point
You've done a great job testing things out, and it's cool that the device still met the original design goals even with a small hiccup in the cell capacity calculation. Your idea about adding different brightness modes and tweaking the physical design for various uses sounds smart. It might be a bit tricky to balance all the needs for nightlight, table use, and flashlight modes, but it's worth looking into.
