Weather Station firmware
A project log for Long Range Weather Station (65€)
A cheap but precise Weather Station (Lora transmission)
jp-gleyzesJP Gleyzes 07/17/2023 at 14:310 Comments
Firmware for the weather station is available on my Github project.
You will find there everything needed to compile and configure your weather Station.
Arduino installation
You will need to install Aduino IDE : https://www.arduino.cc/en/software
Then you should add a reference to your ESP32 board. Simply open preferences and add this link to the "Additionnal Boards Manager URLs" : https://espressif.github.io/arduino-esp32/package_esp32_index.json
 Then you should see your ESP32 board into the board Manager menu
For the Lolin32 lite be sure to select version 1.0.6
Libraires installation
You will need to install a few libraries before compiling your Weather Station... Most of them are installed via the Libraries Manager.
But the Farm Data Relay System one has been patched for my own needs. I strongly recommand that you take a while reading these detailled explainations why I made these modifications. Read the Rezodo project log devoted to this topic.
To facilitate your life I have packaged the modded library into a zip file available on my github project.
Simply install this library via the "add zip Library" menu.
Now you will need to install the following libraries via the "Manage libraries" menu
Radiolib for Lora communications
WifiManager to configure your Wifi Credentials
Telnet Stream for (optionnal) Telnet debugging
Time for NTP time synchro
DS1302 for RTC chip
SolarCalculator to know Sun hours for your location
All this being done you should be able to compile your Weather Station without error !
But still missing to configure it !
