![](https://cdn.hackaday.io/images/8219921688059354660.jpg)
![](https://cdn.hackaday.io/images/4414261688059455333.jpg)
I used a couple the no longer needed LCD pins since they already go to the flex cable.
I removed the original switch off the Pi Sugar and used the pads to facilitate wiring in a new switch. Since the connectors float when not connected, I added a second override switch on the perfboard. It's over on the left next to the connector. This allows me to keep the UPS turned off without the top connected.
![](https://cdn.hackaday.io/images/2339391688059607664.jpg)
