I can manually activate the solenoids with a pushbutton and I get ink on the paper. I think the Arduino may not be able to source the current to actuate the solenoids. Still looking into this. The schematic is also there. Once I get the printer working I'll think I'll set it up on the Pi as a serial printer.
The STA401A should be doing all the heavy lifting. So I'm not sure what's going on. I'll have to hookup the analyzer to it and take some voltage and current measurements of the the actual circuit and mine.
Don
