Close to finished;smoked acrylic face plates
A project log for Epson HX-2023
a reimagining of the first "notebook computer"
donDon 07/01/2023 at 18:460 Comments
Today we spend some time cutting, shaping, and sanding the acrylic to fit. Did I mention it requires sanding? It does, a lot of sanding and fitting. Then we start polishing. 3000 grit to 10,000 grit paper. When you're done with that then it's time to buff it with Novus #2.
I used a rabbet bit to somewhat carefully cut the rabbets. I'm not patient so it was a little rough.
