Using mirror in solar cooker
A project log for Solar Genius
Harnessing the sun's power for eco-friendly and efficient cooking at a small manufacturing cost. Say goodbye to fossil fuels!
wasim-sahuWasim Sahu 07/04/2023 at 16:090 Comments
For making my solar cooker again I first went to the mirror shop. He has a lot of mirrors in thickness. A thickness increase in price also increases. We need the smaller thickness of the mirror as possible. The lower thickness of the mirror will be the lower weight of your solar cooker. So I purchased a 2 mm thickness of mirror that was priced of 4500 PKR at  15.7 USD. First, he cut it in a circle shape. Then again divide it into 4 pieces. Now my round shape was in 4 pieces. Next, Cut it again into small pieces. Every mirror was 1 x 1 inch. All work was done with a diamond cutter.  Every 1 x 1-inch piece is given a unique number with a permanent marker.
