HEXA Printer Issues
A project log for HEXA printer
The HEXA printer is a 3D printer that uses a 6-axis parallel link mechanism similar to the DELTA printer. 6 degrees of freedom allow control
geargeekgear_geek 08/31/2023 at 09:340 Comments
Too many degrees of freedom prevent positional accuracy at the nozzle tip. For example, the figure below shows a heat map of nozzle tip position error for different rotation angles at the same tilt angle.
Tilt 30 degrees, rotation 60 degrees
Tilt 30 degrees, rotation 240 degrees
The error varies depending on the angle of tilt and rotation.
