Hack Chat Transcript, Page 1
A event log for 3D Printing Food Hack Chat
Printing's not just for plastic anymore
dan-maloneyDan Maloney 07/05/2023 at 20:290 Comments
Dan Maloney12:00 PM
OK, now that we've whet our appetites, let's dive in. I'm Dan, I'll be modding today along with Dusan as we welcome Ellie Weinstein to the Hack Chat to talk about 3D printing food.
Hi Ellie, welcome aboard! Can you tell us how you found yourself printing food?
Dusan Petrovic12:00 PM
Hi Dan!
Ellie12:00 PM
Hi all!
welcome everyone!
Ellie12:01 PM
So just a quick intro on me and then I can share more about my journey to printing food and answer whatever questions you all have!
Ellie12:01 PM
I started working on Cocoa Press in 2014 during an intro to engineering class in high school. I graduated from Penn Engineering in 2019 and began working on Cocoa Press full time after 5 years of it being my hobby.
I have also appeared on the Battlebots TV show as a part of team Mammoth and am passionate about the ways we can use 3D printing across industries. When not 3D printing I sing and enjoy weaving, woodworking and glassblowing while fighting for trans rights across the US.
Ellie12:01 PM
As for Cocoa Press - if you haven't checked it out before you can see some cool pictures of printed chocolates here! https://cocoapress.com
Ellie12:02 PM
But the basic and slightly unsatisfying answer is that I fell into it during that insured and sharing class, then, as time went on, I realized that there was a real market for personalize chocolates, and that you could do things with 3D food printing that you can't make any other way
Ellie12:03 PM
The two examples, I always give are making unique textures like the gyroid infill, and creating personalized designs without needing to use a custom mold
Ellie12:03 PM
But that's enough of the sales pitch, I'm happy to chat about how I got here, about food printing, about the tech aspects, chocolate aspects or anything else you all want to know!
Ellie12:04 PM
also thanks for having me Dan!
mda1mike joined  the room.12:04 PM
Ellie12:04 PM
Ellie12:04 PM
Thomas Shaddack12:04 PM
sweet!
Ellie12:04 PM
Dan Maloney12:05 PM
Did you pick chocolate as a material because it's easy to work with, or because of the market demand?
Dan Maloney12:05 PM
My guess is both, but...
Ellie12:05 PM
I forgot I can put pictures in here! The first one is a print in place articulating fish (my favorite print), the second shows the infills and textures I was talking about, and the third some personalization
Ellie12:07 PM
So I originally picked it because I thought it would be easy to work with, but I was wrong 🫣. It turns out chocolate is really difficult because it is so temperature dependent and just temperamental in general
Ellie12:07 PM
It's easy in that it melts at body temperature and solidifies at room temperature, so it's not dangerous, but that's about where that ends
Thomas Shaddack12:08 PM
Are there other behavioral dependences than just the temperature-viscosity one? For a given material?
Ellie12:10 PM
Depending on the base fat, that is used (whether that is cocoa butter, or something like palm oil), chocolate tends to behave very differently. Cocoa butter based chocolate needs to be tempered, while compound chocolate that uses palm oil with the cocoa solid, which is what I've switched to does not need to be tempered
mda1mike12:10 PM
What type of chocolate is used?
Ellie12:11 PM
Tempering is basically a process of heating up and cooling down the chocolate so the crystal structure is aligned. You know a chocolate is tempered when you have a nice snap when you break it. When chocolate is out of temper (like if you leave it in a hot car), you might see white, powdery finish, or even if it has returned to room temperature it may still be soft
mda1mike12:11 PM
Is compound chocolate readily available?
Ellie12:12 PM
I'm currently using a compound chocolate, so it has palm oil and cocoa solids. I have milk and dark chocolate and am working on white chocolate! I'm also working to make my dark chocolate vegan
Thomas Shaddack12:12 PM
I did some chocolate casting experiments earlier but the choc never hardened. Now I see why.
Ellie12:13 PM
yeah! Compound chocolate is available in most places other chocolate is. I have not done enough experimentation with compound chocolate, other than what I'm using, but that's definitely in the works for the next couple of months
Ellie12:13 PM
yeah! Crystal structure of chocolate stuff can be wild. Let me see if I can pull up a diagram of some sort here
Dan Maloney12:13 PM
Why isn't dark chocolate already vegan? Butter?
Thomas Shaddack12:14 PM
What are the ballpark process parameters? Nozzle temperature? Bed temperature? Cooling air temperature? Layer thickness, nozzle diameter, print speed?
What kind of feeder? Heated syringe with a stepper, or some variant on pellet-fed head?
Thomas Shaddack12:15 PM
I assume the cooling air should be chilled.
Ellie12:15 PM
Ellie12:15 PM
Here's an image of a good printed chocolate (although my quality is so much better on newer machines!) and some bloomed chocolate:
Ellie12:15 PM
I'm not actually sure what the purpose of the milk in the dark chocolate was to be honest! But it seems like it's not necessary
Ellie12:17 PM
I'm using a 0.8mm nozzle at about 33.1 degrees C (+- 0.1 C). I don't have a heated or cooled bed or chamber anymore! The chocolate can print in rooms up to 80F, although you can't get overhangs as good at those temps.
In terms of print parameters, I generally print at 0.5mm layer thickness and at a max of 45mm/s
Thomas Shaddack12:17 PM
I think there may be some use of milk fat or milk protein in fine-tuning the rheology/taste.
Dan Maloney12:17 PM
TIL there's milk in dark chocolate
Tom Nardi12:17 PM
@Ellie When I first saw the Cocoa Press at Maker Faire in 2018 I remember it had a water chilling system to provide cold air to blow on the just-extruded chocolate. The modern version seems to have dropped that, is that because of improved chocolate formulation that doesn't need the extra cooling to solidify?
Ellie12:19 PM
@Thomas Shaddack I use a heated syringe with a stepper motor based plunger system! I have a two zone heater that keeps it within +-0.1°C
Thomas Shaddack12:21 PM
How to keep air bubbles out of the syringe? Heat it up enough to be very liquid and wait for the air to separate? If still present, is the compressibility of the bubble problem? Or is it not a problem at all?
Ellie12:22 PM
@Tom Nardi Yes! I have had a lot of various cooling systems. That one was fun. It used peltiers to cool the air, and a Computer water cooling system to cool, the hot side of the peltiers. The last version of the printer that I made was fully enclosed and insulated, had a double paned argon filled glass door, and was basically a mini fridge. While it worked really well, it was incredibly expensive to make, and tended to cause more clogging issues with the extruder than this one. the new chocolate formulation is definitely one of the main reasons that I don't need that extra equipment and that the printers' price has dropped so much
Ellie12:23 PM
Also for reference - I opened the printer up for reservations a couple months ago and will be shipping them this fall! They are $1,499 as a DIY kit. I'll have fully assembled ones next year. The old version was almost $10k so I'm pretty happy with the trajectory 🙂
Thomas Shaddack12:24 PM
Can you compound your own chocolate? Eg. start with high-cocoa formulation and add fats blend to tune the processing characteristics?
That way we bypass all the conching and other solids-processing part.
Ellie12:26 PM
Keeping air bubbles out the syringe is difficult! Some combination of heating it up warmer than you would print it, and tapping it or using a vibration table seems to work pretty well. Compressibility of the air bubbles is definitely a problem with a plunger based system. That is one of the main benefits of an air pressure base system. An air pressure base system uses constant force, where a motor controls the displacement of the syringe. Air bubbles will therefore affect motor base systems way more than pressure based systems.
Ellie12:27 PM
You can definitely make your own chocolate but it's a messy process and a bit tough to repeat, since it's not just about the ingredients and proportions of those ingredients, but it's also about the temperatures at each step
Thomas Shaddack12:28 PM
Vibration table... what about attaching a little phone-class vibration motor to the syringe itself, to assist the flow?
Thomas Shaddack12:29 PM
I saw shakers for material flow assistance in industrial equipment.
Ellie12:29 PM
That could be cool! I was at MRRF a couple weekends ago and they were suggesting that you can just use the gantry of the 3D printer to shake the cartridge which I think would be really cool for making one off chocolate cores
Thomas Shaddack12:30 PM
Thought. This would allow us to leverage thixotropy. The vibratory excitation would keep the material fluid through the nozzle, and once still it'd solidify faster.
Shaking the gantry may lead to fatigue and wear. Better limit it to the head itself?
Ellie12:30 PM
once you have the chocolate core you basically want the chocolate at the lowest temperature that it will flow at so it solidifies quickly
Ellie12:33 PM
I've also had a crazy idea that I would love to explore more one day, where you basically just put a ton of force on solid chocolate. That force should heat up the chocolate in the nozzle just enough to realign the crystal structure and extrude the chocolate, creating a tempered chocolate printer without heaters
Thomas Shaddack12:33 PM
Random thought. M600 filament-change command that moves the head off the workpiece. Can be used in conventional printing for inserting eg. nuts into the plastic. Here it could be used too, for inserting a different kind of nuts.
Ellie12:34 PM
I'm not sure it would work, and maybe you would still have to heat up the chocolate just a little bit in order to make that work, but it would be really cool
Ellie12:34 PM
yes! I have done experiments with putting marshmallows and edible glitter inside of hot chocolate bombs with pauses in the print G code
Ellie12:35 PM
It does well! I want to play around with caramels and other delicious inserts. I'm allergic to nuts though, so none of those for me!
Guru-san12:35 PM
Hey Ellie! Love your work~ I can imagine you tried to make chocolate filament but settled on using a seringe for now, what would be the biggest challenges if you were to go with filament?
Thomas Shaddack12:35 PM
The gyroid infill is all interconnected, there are holes within. The same insertion can allow pouring in booze, syrup, other materials... and then the object is sealed by the rest of the layers.
Ellie12:37 PM
@Guru-san ooh that would be tough. If I were using a traditional 3D printer, I would need to make sure there are no brass pieces, and that the entire hot end assembly is food safe. I'm also not really sure how to get chocolate into a spool without it breaking. That would be a cool way to turn a conventional printer into a chocolate printer though
Dan Maloney12:39 PM
That's an interesting point -- food-safe wetted materials. I guess that basically means stainless steel, at least judging by the miles of stainless piping in the typical food processing plant
Alli Raine Chapman12:39 PM
How easy is the printer to clean?
Thomas Shaddack12:39 PM
I think it'd be easier to print a new head for the printer. And either swap them or strap the choc head on the plastic head. I don't see how to make chocolate filament hold together through the feeder.
Ellie12:40 PM
Yep! I use a lot of 304 Stainless steel!
Thomas Shaddack12:41 PM
There are many food-grade printable polymers out there. I'm just now experimenting with polypropylene printing. For elastomers, eg. for moulds, I'm about to try out TPE (not TPU, TPE is a copolymer/blend of polyolefin and styrene-butadiene-styrene. Said to be food-safe.)
Ellie12:41 PM
In terms of cleaning, the chocolate only touches four pieces that can all be removed without any tools and washed in the sink. Two are 304 stainless, one is an injection molded plunger (polypropylene), and one is the silicone baking mat that is my build plate
Then there is the indirect way of making the tooling, by printing a template and then casting silicone. Which is cheaper for baking than messing with printing PEEK.
Ellie12:41 PM
It's honestly easier to clean than most conventional chocolate equipment, but maybe a bit harder than some plastic printers
Thomas Shaddack12:42 PM
Any assistance used for bed adhesion? Or does it hold without any glue/juice?
Ellie12:42 PM
yeah silicone casting or vacuum/pressure forming over a printed or milled mold both work
Thomas Shaddack12:43 PM
The casting-over-printed allows use of acetone polish. (Or alcohol polish, for PVB.)
Ellie12:43 PM
The silicone bed works great! in a cold room it could start to warp a little bit, very similarly to an ABS, but I usually don't find that to be the case, especially since we ditched the cooled build chamber
Alli Raine Chapman12:44 PM
can you wash the parts in the dishwasher?
Ellie12:44 PM
How has polypropylene printing going? I wanted to get some MJF (multi jet fusion) parts in PP
Thomas Shaddack12:44 PM
Does the print-friendly chocolate compromise taste/texture in comparison with the ordinary one?
Ellie12:45 PM
Yeah the steel and such can easily go in the dishwasher, the other two pieces should be fine as long as they don't get too hot. Probably top rack only type of thing
Tom Nardi12:45 PM
Obviously chocolate is the main goal here, but what kind of support is there for extruding other edibles like peanut butter or icing? Can you run the extruder motor with the heater off (something that normal 3D printer firmware would generally prevent you from doing) for materials that need to stay room temp?
Thomas Shaddack12:45 PM
There are different choc blends for different markets just because the average temperature/weather in the area. Different for Morocco vs Finland...
Thomas Shaddack12:46 PM
You should be able to trick the firmware by using a fixed resistor instead of the thermistor, and disconnecting the head heater. Then setting it to temperature that equals the temp reported by the resistor. May work. Patching firmware may be easier.
Ellie12:47 PM
Yes! You can definitely print without the heater. I haven't done a ton of work on printing any other materials besides chocolate. I really want to try printing candle wax, cheese, and even ice sculptures if you put the whole machine in the freezer
Thomas Shaddack12:47 PM
Not just icing. This is a kind of material with generic uses. Chocolate, icing, pottery clay, silver art clay... anything that is or can be a paste.
Thomas Shaddack12:48 PM
Candle wax may be tangentially similar to the Moldlay material, which is a filament for printing lost-wax casting things.
Tom Nardi12:49 PM
Good point, lot of exciting possibilities for past extrusion that aren't necessarily food related.
Ellie12:50 PM
yeah! Some people have approached me for using the printer in medicinal settings and as a less expensive glue dispensing bot for low volume manufacturing
Pete Willard12:50 PM
The viscosity of everything needs to be known...
Thomas Shaddack12:50 PM
And we can go multimaterial then. Use table salt in binder, for dissolvable supports that can survive sintering temperatures for metal. For internal supports, variation on salt inserts for casting hollow things inside engine pistons.
Thomas Shaddack12:51 PM
Add a 3d scanner to see the bed, and you can deposit stuff on other stuff.
Ellie12:51 PM
ooh yeah someone wants to add the 3D scanner to print onto cookies!
Pete Willard12:52 PM
hehe
Ellie12:52 PM
currently I use a hot knife to remove any supports, and then that's my snack for having done it 😄
Thomas Shaddack12:52 PM
A camera on the head, and then photogrammetry. Or a cheapo 1d line lidar. Or a time-of-flight camera module, I saw some that's quite cheap.
Tom Nardi12:53 PM
I was very excited about the PrintrBot Paste Extruder add-on, but it never really went into mass production and remained just an experiment (plus PrintrBot folded not long after). Glad to see we'll finally have a DIY-friendly option out there with Cocoa Press.
Tom Nardi12:53 PM
Thomas Shaddack12:54 PM
Candle wax could be printed into water. For immediate cooling after exiting the nozzle. May cause lots of problems though with the trapped water later.
Ellie12:54 PM
and then fun fact, Brooke then designed the original procuisini food printer after that which did go on sale commercially, but was pretty expensive, especially for their dual extruder version. I forget the exact details at the moment
Ellie12:54 PM
Ellie12:56 PM
I wonder if you could create 3D structures (instead of printing layer by layer) with printing wax inside of water like some of the bio printers can do, printing into gel
Thomas Shaddack12:56 PM
Or print gel into water using the spherification trick from molecular gastronomy.
Ellie12:57 PM
oh yeah that would be super cool too!
