Almost there...
A project log for Automatic workstation locker
Life is too short to always remember to lock your workstation
enzo-lombardiEnzo Lombardi 07/05/2023 at 19:160 Comments
A couple of small improvements.
  1. Made the switch to the Attiny85, digispark flavor. This toy is fantastic and has the bare minimum needed to emulate the keyboard and...
  2. Added a neopixel ring. When someone is present a green LED will circle; if no presence detected, the ring will show a Knightrider KITT type of anymation. See video here.
Since the Attiny85 doesn't seem to provide pull-down resistor, a 200ohm is required. In the code the number of LEDs is hard coded. The KITT animation won't work with less than 4 LEDs and will likely crash the app. Caveat emptor
