The dreaded zero cross
A project log for TinyD, 8-bit stereo class D amp from Attiny85
The goal of this project is to create an 8-bit 32khz class d amplifier, using filterless topology, controlled by an Attiny85
george-gardnerGeorge Gardner 12/31/2016 at 12:220 Comments
Well, I've run into the same issues I was having with the project from 2014. I don't know if it's related to switching times, but when the PWM crosses from positive to negative, there seems to be a good deal of distortion, and the audio quality suffers at lower volumes.
