Figured out my problem
A project log for PH & Temperature Sensor to monitoring Hydroponics
Sensor platform for monitoring PH, Temperature, 02 absorption, and conductivity for Hydroponics Systems
brian-whartonBrian Wharton 01/05/2017 at 22:240 Comments
I was getting an invalid voltage reading on the ADC converter. and after tracing all my soldering, I realized that I connected to the wrong Analog pin. Dolt!!! Anyway, now everything working great.
Next steps, adding Dissolved O2 sensor and switch out to post data to Azure IoT hub.
new pic below:
