Quick Update 23/01/23
A project log for UltraTower 2023
Grow vegetables with ultraponics tower
j-gleyzesJ Gleyzes 07/04/2023 at 05:310 Comments
The DC-DC Buck Step Down Converter problem
I use this module (CN3903 3A) to convert 12V to 5V to power two components: the esp32 and the 5V mini pump.
However, it is not capable of feeding both at the same time. After several tests, activating the pump causes the esp32 to crash.
But separately everything works.
Several solutions are possible:
For the moment I use solution 1 which allows me to test easily.
Disc nut optimisation
The old STL design, was too closed on the disk creating a water droplet retention preventing the creation of fog afterwards. The new design seems to solve the problem.
New PCB
I'm still testing the latest version of the PCB, the fog creation is good now I'm waiting to see if the disks don't get damaged over time.
