Quick Update 03/11/22
A project log for UltraTower 2023
Grow vegetables with ultraponics tower
j-gleyzesJ Gleyzes 07/04/2023 at 05:290 Comments
I changed the ESP32 code, the new code is in the project github.
The changes:
Water level sensors get damaged very quickly even when using the capacitive function of the esp32. I think I will use stainless steel wire to limit corrosion.
The root system of plants is quite impressive. The lettuce on the top left has already been cut three times (leaving some leaves on). It has grown back to its pre-cut size in a week.
