First prototype of a 3D printed driver:
A project log for Batteryless Supercapacitor Solar Speaker
Whilst listening in a sunny spot it stays 100% charged! If drained a charge of 10 minutes can easily get you 6 to 8 hours of playtime.
jamie-matthewsJamie Matthews 10/12/2023 at 15:240 Comments
I started work on a replacement for the regular speaker driver with a completely DIY driver.
At the moment I am testing out the voice coil design and then once that has been finalised I will move on to the magnet housing.
First tests of the voice coil sounded very promising but I will need to alter the design in order to fit more windings as they are currently only 2ohms and I don't want to decrease the wire gauge to keep assembly for children easier.
