The Crosberry Pi is a media machine, in that it does a great job of playing lofi hip hop and radio broadcasts at a decent volume and with that classic Crosley sound. Making use of the speakers in the case was my brilliant wife's idea. We used a donor 3.5mm audio cable and soldered it to the existing board, which is easily accessible once you remove the plastic turntable top. I removed the RCA outputs and used the hole in the case for the USB hub's power cable, which powers the entire deck.
