The ultimate goal for Plastic Scanner is to become a fully portable unit. That looks increasingly doable. Before getting the production unit ready, there are a few things to smoothen out. I saw a few in their Discord server (and that sound all too familiar!):
- Testing testing testing
- "Great! this is the perfect component! What do you mean "0 in stock, Ship date estimate 2025"??"
During the testing phase there will be a lot of plastic samples, and the devboards are going to be moving around a lot. PCB's are pretty sturdy, but a lot of touching cannot be good for them.
I took a long look at their devboard in order to see what I would be working with.
![](https://cdn.hackaday.io/images/5513561688648426499.jpg)
![](https://cdn.hackaday.io/images/877571688648433995.jpeg)
The first devboard was an Arduino UNO, but they are still exploring different options, one of the chief factors mentioned above is the supply chain resilience. There are a few factors that remain the same, however: LED's array on top of it, shape, assembly holes.
