The CH32V203 is an industrial-grade microcontroller (MCU) designed for general-purpose use, with low power consumption and enhanced performance. It is based on a 32-bit RISC-V core, supports the RV32IMAC instruction set, and can operate at clock frequencies of up to 144MHz. The MCU's power consumption is highly efficient, reaching as low as 45uA per MHz. Additionally, the CH32V203 integrates a USB interface with two channels, enabling both USB Host and USB Device functionalities. It also provides a CAN interface (2.0B active) with one channel, up to two OPA channels, four UARTs, two I²Cs, a 12-bit ADC, a 10-channel TouchKey, and various other peripheral resources.
