Keyboard design
A project log for North American Cyberarms Cyberdeck
Cyberdeck from an old pistol case for the 2023 contest
patrick-taitPatrick Tait 07/09/2023 at 19:210 Comments
The keyboard is the heart of this project, it's designed to be compact, one handed and use muscle memory to allow it to be learned quickly.  It's based off of 2 ideas: Half qwerty and butter stick.
Half qwerty works by mirroring the keyboard whenever a key is pressed, in this case the space key.  Pressing it causes Q to become P, F to become J, C to become N, etc.  The idea is that you are using the same finger and the same row, just on the opposite hand.  I've been using it for a long time and it is very functional and natural.
Butter stick keyboards work by minimizing the rows.  All the letters reside on just 3 rows, and we can simulate that on 2 rows if you press the top and bottom row to access the middle:
Cut the butter stick in half, add a 5 way joystick to let you mirror and shift and you have a handy keyboard that technically is qwerty compatible
