first custom effect for the stargate clock, a dial sequence, which will run every hour on the hour.
takes roughly 45 seconds to complete, but that varies as it 'dials' a different address every time.
it dials all 9 chevrons... this doesnt happen in SG1 but the talk about it, and it is done in SGU, between destiny and earth.
had a quandary between keeping it SG1 authentic and satisfying the OCD, but seeing as the whole gate (the leds at least) will need to be visible, i thought it best to do the lot.
the leds are a bit bright for the camera but you can see what its doing :-)
David Hopkins
