Initial thoughts
A project log for Stargate LED Clock
An LED clock using the adafruit 1/4 sections to make a 60 LED ring. Although not a new concept, it should be expandable to other variations.
david-hopkinsDavid Hopkins 07/15/2014 at 15:230 Comments
I have cobbled together bits from the arduino Time library and the FastLED2 library, led segments ordered and are on the way, RTC is kicking about in a drawer somewhere.
Need to decide on colourscheme/UI decisions.
initially, just a clock with time set from serial port, but would like an alarm feature too
therefore buttons may be needed OR and IR interface (i have a few remotes kicking around)
if buttons or IR i need to show what mode im in. for editing h/m/s i can flash the pixel. if in alarm mode, make background dim red instead of black? maybe.
Clock first, other things later.
so for the first version:
H/M/S using R/G/B with ability to set/get time from serial connection.
this can be tested with other RGB strip until the actual circle arrives.
