Solder mask laser etching? part 2
A project log for Laser4DIY
Laser4DIY is an open-hardware machine for producing PCBs by ablating copper with a laser
fablab-mnchenFabLab München 07/27/2023 at 12:120 Comments
Last time we did a test to see if solder resist film can be laser engraved, see https://hackaday.io/project/191904-laser4diy/log/221159-solder-mask-laser-etching
That looked quite promising, so we went one step further and tried to put a solder resist mask on a PCB we created with Laser4DIY:
That worked...  but not exactly great. :-(
First of all, this PCB is tiny. It's our Laser4DIY Coin made by Alex, measuring only 17mm in diameter. So the pads are tiny as well and that caused issues:
Definitely need more experimentation in that area...
