Goals
- Standalone: can mine directly to your pool over WiFi. No External computer needed.
- Embedded: low cost, low maintenance, high availability, high reliability, low power.
- ASIC: based on the very efficient BM1397 from Bitmain.
- Versatile: solo/pool mining, autotune power/heat/efficiency.
- Open Source: All design files are provided.
Bob
What SoC would you recommend using in a HAT/Shield design?
