ESP32 C3 Nano
Arduino compatible Nano-sized development board powered by RISC RISC V ESP32-C3 Chip
Public Chat
Starting from
$6.00
andrey-malyshenko has 716 orders / 22reviews
Ships from Poland
The ESP32 C3 Nano is an Arduino Nano compatible development board, designed to provide enhanced computing power, wireless connectivity, addressable LED capabilities, and a built-in programming and debugging interface. It is based on the ESP32 C3 chip, which provides improved processing capabilities, increased memory, and wireless connectivity compared to traditional Atmega variant. The board maintains compatibility with the Arduino Nano form factor, ensuring easy integration into existing projects and making it a drop-in replacement for the traditional Arduino Nano board.
aaaaaa wrote 07/15/2023 at 18:28 point
please add lipo, solar panel, aa 1.5 v 18650 3.7 steper updown 1-25V
andriy.malyshenko wrote 07/16/2023 at 10:41 point
That's a big ask in this size:) Can you explain your use case, I might do it in bigger form-factor.
aaaaaa wrote 08/04/2023 at 17:22 point
lipo input and UPS similar in https://1bitsquared.com/products/orangecrab
or steperup-down from 1V to 25V input  similar https://www.pololu.com/product/4082
power is alvays trouble in small projects
