Engrave conductive materials with a "Wagner Hammer"
A project log for Spark erosion: Detailed view, simple machinery
Have a close look at how Electrical Discharge Machining (EDM) works and what can be achieved with a simple setup
norbert-heinzNorbert Heinz 10/14/2023 at 10:090 Comments
A "Wagner Hammer" or "Neeff Hammer" is quite simple and essentially consists of an electromagnet and a breaker switch. The electromagnet pulls the hammer inward as soon as a current flows through the coil. If that current is interrupted, the hammer falls back down. The trick is to let the current through the coil flow via this hammer so that it acts as a breaker switch for the coil. Now, connect one terminal to the coil and one to your workpiece and you are ready to do spark erosion.
It is a simple add-on for any CNC or 3D printer and a great way to teach numerical control. You can engrave a piece of metal for your students without sharp, rotating tools or dangerous laser light.
